ProComp Extr MT vs. Nitto M/G
Not, saying your wrong Wandell. Like I said I had heard the same thing and it was from a very reputable shop round here. It comes down to each individual tire. I would say cross rotating them will work with no problems 9 out of 10, even 99 out of 100. But in my case I am going to stick with that old rule of thumb. If you cross rotate you run a risk (no matter how small), where as if you rotate front to back, you run absolutely zero chance. The other problem with the cross rotate is once you wear a tire a certain way, it has certain groves and a specific wear pattern, now crossing them up and forcing them to turn a different way may cause problems (especially if you wore them in some type of un-even pattern). I don't know about you guys, but shelling out the cash for tires is a fairly big expense so I will take the precautions and take as good of care of them as possible (except thrashing around off road). But thanks for the info, hearing that u cross it up a lot makes me think it was more the tires than the rotation.
I'll stick to what actual tire manufacturers recommend for tire rotations.
http://www.tiresafety.com/maintenance.asp
