Anyone with a 97 running 22's??
Well I was wanting to buy Eagle Alloy Series 187 wheels. Still a 16" wheel. Do you recommend a size for that wheel? 16x8? or 16x10? I want the tires to stick out a little bit. Maybe an inch or so. Nothing to crazy.
**EDIT** I cant find a 2" for my truck. All I can find is 1.5" or 2.5" Do know of a place online that has them for my truck? And if I cant find one, is their another brand you recommend?
If you plan on ever adding a suspension lift or a set of lift spindles, I'd go with the 16x8's. The reason is lift spindles or a full suspension lift will increase the front track width and make 10 inch wheels stick way outside the wheelwells.
Also, I'd go with the 2.5 inch Daystar. Check 4Wheel Parts, National Tire and Wheel and Desert Rat's websites.
