Yep, we need to know what exactly you are referring to. There is minor rubbing (that is hurting nothing) and major rubbing (where tires and sheetmetal are being damaged and everything in between.
They will rub the control arms at full steering lock. It won't damage anything. I'd be more concerned about the tire wear caused by running a 325mm wide tire on a 7.5 inch wide wheel. I'd suggest something slightly narrower.
Sorry, I thought I read 325/60's. A lot of members have run 305's on oem wheels with no problems even though they are a little too wide for the oem wheels.
