tire help
Old 08-25-2007 | 10:55 AM
bagedtaco's Avatar
tire help
i'm sure the ? has been beat to death 10x's over, but i'm gonna ask again.
i want to get some 20's for my truck with larger a/t tires, but don't want to do a lift/leveling kit.
i like the cooper ltz and nitto terra graps, and would like to run these. what is the largest i can go with out rubbing.
if i do a leveling kit, what else needs to be done? ie allignment.....
'06 xlt 4x4screw
Old 08-25-2007 | 11:05 AM
wandell's Avatar
If you get a wheel with specs close to the oem wheel (20x8.5 with 5.5 inches of backspacing) you should be able to fit 305/55-20's (33x12.50). I'd suggest adding a 2 or 2.5 inch Autospring leveling kit. All you have to do after the kit is installed will be to get an alignment.
