Mickey Thompson Baja MTZ Radial
It's just that i needed the extra leaf because i load thing in the box and i didn't like the feel without the aal.
For the cost, it was 150$ CAN with install if i remenber correctly.
efox the easiest and cheapest way to fit 35s is too get a 2.5" Autospring front leveling kit. They are like $80 on ebay. You could install it in a few hours and then get an alignment. This will fit 35s just fine on the STOCK WHEELS. Now if you want aftermarket wheels then thats where you run into needing more lift because of backspacing on the wheels.
