Will these fit or rub?
Old 08-27-2007 | 05:17 PM
RGV_F150's Avatar
I'm on the verge of getting some gear alloy wheels and have a few ?'s They are 20x10 with a 25mm offset (not sure - or +) and I'm gonna run a mickey thompson atz 305-55-20 tire. Is this gonna rub and if so how can I fix it? trimming? Also I want them to stick out a bit, will this offset allow them too? Thanks guys.
Old 08-27-2007 | 05:29 PM
hawg_man's Avatar
Is it a 4x4? Do you have the stock 18's or 20's?
If stock 18's with stock tires they would stick out about 4'' further than stock.....
I would think those would rub no matter if it is a 4x4 or not.....
Old 08-27-2007 | 05:34 PM
RGV_F150's Avatar
Yeah its a 2007 4x4 with a 2.5 autospring kit. It has stock 18's on it. So it will stick out 4 inches and rub at full lock?
Old 08-27-2007 | 05:48 PM
DNGrumpy's Avatar
Are you sure you have that right??? 25mm offset makes them 1" on one side and 9" on the other. That cannot be made for an F150...
Old 08-27-2007 | 05:56 PM
hawg_man's Avatar
they would have 4.5'' backspacing.
1 inch more than stock
rims are 2.5'' wider
and the tires are about 1'' wider than stock, so that would be another half inch.
so 4''
edit: Oh, I see what you are saying, I looked and I didn't see any gear alloys that were 10'' wide, sure they aren't 9'' wide? I saw those in 6x135
Old 08-27-2007 | 06:12 PM
DNGrumpy's Avatar
I was not thinking he meant 1" more than stock I was thinking 1"/9" which made no sense at all... 4.5"/5.5" makes more sense
Old 08-27-2007 | 06:22 PM
RGV_F150's Avatar
Ok, all this is confusing. The guy said they come in 20x10 and 20x9 but the the 20x9's would only stick out half an inch. So i should get 20x9 with a 4.5 backspacing? Any pics of how these would look as far as sticking out?
Old 08-27-2007 | 06:36 PM
hawg_man's Avatar
I think you would probly need to find some with 5.5-6'' bs
Old 08-27-2007 | 06:49 PM
RGV_F150's Avatar
OK ended up ordering 20x9 with a 5.5bs with 305-55-20 mickey thompson atz's. Heres what the rims look like.
Old 08-27-2007 | 06:50 PM
RGV_F150's Avatar
Thanks for your help guys.
Old 08-27-2007 | 06:53 PM
hawg_man's Avatar
those should be great... They'll stick out about 2'' further... Sweet Tires too!
Old 08-27-2007 | 08:10 PM
keith_bennett's Avatar
I agree.
