What tire to buy????
I have a 2004 fx4 with the 18's I have decided to go with either 285-65-18 or the stock 275-65-18 But i am undecided what tire to get here are the choices:
bf Goodrich 285-65-18 ta ko's
bridgestone duller revo's 275-65-18
Terra grappler's 285-65-18
any other suggestions would greatly be appreciate. I do some off roading but here in NM i do allot of skiing and higher altitude driving so traction in poor condition is a must.
thank you
thank you
Here's Tireracks survey on the top AT tires, so take it for what it's worth:
http://www.tirerack.com/tires/survey....jsp?type=ORAT
Notice the worst at the very bottom. Those are the tires my truck came with from the factory. I got rid of them pretty fast.
One thing to look at is that the BFG's are a E rated LT tire where the Bridgestone's are a P rated tire for the extra money your getting a lot stronger tire. I've ran P rated tires and never had troubles with them however I don't tow a lot or carry heavy loads if you do this is something you might want to consider.
https://www.f150online.com/galleries...cfm?gnum=10466
I'm going with the nitto's in the next couple of weeks for my truck. 315/75/16 . The guy i'm buying them from has them in a 285/60 18 for $750 or a 285/65/18 which is a 32.5" tire which should fit for $890. Check and see if there good prices. Also discount tire direct has good deals on the nitto's in my opionion.
