backspacing and offset question..
Alright, I currently have a 05 F150 FX4 on the stock 18" rims/tires with a 2.5" autospring lift.
I've decided to go with the following wheels/tires:
325/60R18 Mickey thompson baja claw radials
18x9 Moto metal 951 chrome rims
I'm just not sure what bs and offset I need to get so I don't rub.
Any info is appreciated.
Thanks,
Aaron
Thanks,
Aaron
I think I have seen them in 4.5 inches of backspacing also. Hey Wandell, could you do me a favor and go to 4wheelparts if you have a spare moment, and go to the MM 951's 6X135 18's and look at the backspacing/offsets that they have listed? They confused the crap out of me. I think they may have them mixed up or misprinted. Or maybe I am just confused ----- I don't know! I am wanting the rim with the closest to 5 backspacing I can, get but I figured that would be close to a 0 for offset. Anyways Thanx
http://www.4wheelparts.com/PDT244675.aspx
http://www.4wheelparts.com/PDT244674.aspx
Those are your two best choices.....
Which one would stick out more. I thought that the lower the backspacing was, the lower the offset should be. I think that a 5 for backspacing=0 offset for this width rim but this shows otherwise. Whats up with that!
Originally Posted by JDB
Exactly the 2 I was confused on!
Originally Posted by Brian 5.4
Mind you this is only on a 9" wide wheel. When wheel width changes, offset does too, even if backspacing does not.
