A noob question
A noob question
Does anyone know what the max size tire (preferably BFG AT KO) i could get away with on a 07 FX4? It came from the factory with 275 55 20's and they are killing me! They almost look like low profiles! I am to paranoid about the leveling kit and warranty issues to do one of those. Any ideas? (I get a headache trying to figure out all the metric crap)! Thanks.
BFG makes a 285/55/20, which is roughly 1/2" wider and 1/2" taller than your stock tire. You may also be able to do a 305/55/20, but I don't know if you would need a levelling kit to clear that comfortably. Hopefully Wandell will come along and chip in...
Check out this link for a tire size calculator http://www.1010tires.com/TireSizeCalculator.asp, you can go on the BFG site, or tirerack.com to get all the sizes, then plug them in and compare.
