325/60/20?
325/60/20?
I have a set of the 325/60/20 bfg km2 on my screw with a 2.5"
leveling kit the tires rub at full lock only on everyday driving
conditions however while offroading they are going to be a problem
what are my opinions?
1-body lift
2-suspension
3-?????
I don't really have the funds to do the suspension now
thanks for any help
1-body lift
2-suspension
3-?????
thanks for any help
body lift, going bigger is never a bad thing! and they can be quite cheap if you are pretty handy and can do the work yourself.
you could also, nobody hurt me cause I am as big a fan of bigger tires as anybody, go down to a 305 or something.......that is if, and only if you don't wanna shell out the money for a body lift.
I will be honest, I freaking love your truck, the color, toolbox, love the oem 20's and 325's stuffed!
you could try a spacer up front, not the best solution (i ran 1/2" spacers on my silverado, it worked for me til i bought new rims) , but it might work for ya, but your still gonna rub. the other cheapest option is a body lift. i love your set up too, but those tires are damn pricey, but what get what ya pay for. i dont think a body would look too bad on your truck
Originally Posted by wandell
I'd go with a 9 inch wide wheel with 5 to 6 inches of bs.
Your truck looks great with the OEM rims and BFG's, I'd probably just put on a body lift.
You could always put the stock Junk-a-rellies back on until you have the funds to lift it. Or you could buy a smaller tire, that option really doesnt make sense though. On the spacer issue, I would stay away from those. I tried a 1/4" spacer on my front and the shop worked for 2 days trying to get a terrible steering wheel shake corrected, they never could fix it. I dont like spacers at all, thats just my opinion though. Good luck.
Originally Posted by Nebraska
I could be wrong about this, but if the tires rub on the A arm a body lift would not solve the issue, would it? I have thought about aftermarket wheels, but am afraid the 325's would rub on the fender flar due to being pushed out.
Nebraska
![help](https://www.f150online.com/forums/images/smilies/help.gif)
Nebraska
the km2 must be wider than the a/t because i had to run the .25" spacer to get them off the ball joint and had to do some trimming
the body lift was just an idea to get a little more room in between the tire and fender
what is gonna end up happening is this is gonna end up on the classified section so i can start over with the rize setup
would the 325 with an 8" would look to small
