OEM recommended mileage for bearing repack?
None that I am aware of - usually do it only whenever I do a full brake job where the rotors are turned.
I suggest that at 55K, you have at least that many more miles to go before worrying too much about this, unless you have an unusual event such as a brake dragging that significantly heats things up, a 'through the river and into the woods' expedition, etc.
Also, you can see my generation truck in the sig, so I'm not totally up to speed on the newer stuff - are you sure that your generation doesn't have the sealed bearings???
On a 4x2 you may be correct. On a 4x4, I'm certain you cannot service the bearings. I looked into this at one point because I was going to repack my bearings. I assumed your truck was a 4x4. My apologies for the confusion. You may want to search the site. I'm sure there must be some additional info on a 4x2.
-Craig
-Craig
No O'reillys here in the Orlando area that I know of - probably a NAPA machine shop or some other local but haven't checked yet. Have heard great things about them though...
The OEM rotors would be good spares to turn after new ones wore in, I just hate breaking up the day running from place to place when my main ride's up on stands... Much easier just to have everything in 1 place
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
The OEM rotors would be good spares to turn after new ones wore in, I just hate breaking up the day running from place to place when my main ride's up on stands... Much easier just to have everything in 1 place![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
My Manual says to repack the bearings every 30k miles. HOWEVER, I had 120k on mine when I did it. I do not know if the previous owner had it done or not, but, from the looks of things it wasn't done. I have had it since 80k miles. I like to replace the whole shebang when I already have it apart.
