Frozen Slider Bolts
Frozen Slider Bolts
I am doing a brake job on my 03 F150 and all is going well . But when I inspected the slider bolts the top slider bolt was working fine but the bottom one is frozen in place. I have been trying to move it by puting oil inside the small dust boot and hitting it with a dead blow hammer for about a half hour with no luck. So..If I cant get it to move is it safe to put a little heat to it or should I just keep oiling and tapping it with the hammer?
By slider bolts, you mean caliper bracket bolts, the larger 5/8" or so bolts? I would if you can use a air impact gun and/or a breaker bar, they should at leasy budge with either of those. There is factory and should be when re-assembling some blue threadlock Loctite on the threads but should still come off. Heat? I don't know if I'd use the bolts again then.
Did it turn enough to remove the caliper? If so, I would spray some more juice in the boot then press the end of the bolt against something while turning it (block of wood would be good). Preferably with an impact. Keeping pressure on it while turning should help it back out.
If you mean it won't even turn to remove the caliper then yeah, I would use a little heat instead of taking a chance of breaking it off in the spider or caliper holder.
