Abs Code P1635
From http://www.ford-trucks.com/article/i..._Overview.html
There are four basic code categories (click for details):
P - powertrain
C - chassis
B - body
U - future diagnotic systems
Don't see that specific code - but the sequence suggest it's a driveline problem.
P - powertrain
C - chassis
B - body
on
"P1635" is not an ABS code.
The code indicates that the measured tire size or axle ratio does not match what has been programmed into the computer.
Are you, by chance, using an aftermarket tuner or programmer, have had the PCM replaced or reflashed, or driveline/axle/tire modifications?
Steve
Steve
