Cooper STTs on 06 Lariat 4x4 with 18s - Largest size?
I am looking to purchase a set of the cooper discoverer stt's and put on my stock 18" wheels, and I wanted to go as big as possible without any rubbing, add. cutting necessary, other issues...
The guy at this place said that the 275-70-18s were the biggest that I could get on my wheels, but wanted to see if anyone had any additional insight...
Here is a listing of all the sizes that they have for 18" wheels:
http://www.discountedwheelwarehouse....%2DSTT&Sortby=
Any insight that you could provide would be VERY appreciated as I know very little on the subject...
Thanks very much for your help...
Mark
Mark
Mark
Mark
Re: sizes
Thank you both very much... I appreciate your insight...
I do plan to install a 2" leveling kit, and plan to buy the cooper stt's... What about as far as the width of the tire? how wide of a tire can i safely go on my stock wheel?
Isn't the stock wheel width ~ 9 inches or so? Will I have problems finding someone to install a 12 ~ + width tire on this size wheel?
basically, i will be using 99% on the road...no snow... possibly a little mud...
If wheel is 7.5 inches wide, won't installers balk at installing 12" + tire or is that not that big of a deal?
ya some say its too wide of tire to put on a stock rim, but there are plenty on here running 35x12.50 on stock 18's, with a little frame rub. if you do mostly highway driving, i'd go with a 2" level and the 305/65/18 BFG ATs, they will last ya at least 50k miles for sure.
this is hmfic's truck he has the 2" autospring and 305/65/18 BFG's awesome setup
more pics in his gallery
https://www.f150online.com/galleries...628-188952.jpg
this is goldmembers truck on 305's
i'm not sure if cooper offs a 305/65/18 but im sure they got something close.
Those 305s look reaaally good.. I found a 305/60/18 in the cooper discoverer stts, that I think I will be getting..
Still having problems finding a decent shop around baton rouge, la area to install 2" leveling kit..
Anyone had experience with treads and care, kirks auto, or any other shops around this area?
Thanks again...
Thanks again...
Kirks is waaay too expensive. Never dealt with treads and care, but I think they were the cheapest when I priced the 305 BFG's, so maybe they're good on the coopers too. Installing the leveling kit is really easy for a shop, I would take it to a neighborhood mechanic if you can. Give them the directions and see what they tell you - I've seen people charge $200 (Kirk's) and some charge $20. I wish I could recommend a specific place to go, but I can't.
I started to call alignment shops and explained the process to them, and I called one and he said come in and let him take a look at it, so I brought in the truck and kit, and an hour later he had the truck aligned and had the leveling kit on for like 140$ could not have been more happier. I called the local four wheel shop and they wanted 350 400 to do it. SO just call around. Most people that are mechanically inclined will have zero problems doing this, just fine the best deal.
