When Changing Wheel and Tire Size
Originally Posted by STXDriver
When changing the wheel and tire sizes from stock OEM 18's to OEM KR 20's is it possible to have the speedometer recalibrated?
97-98, and prolly earlier you need to change the VSS gear located under the truck next to the tranny. Its just a plastic gear you buy from the dealer for about $10. But if the change is less than a couple mph its not worth the trouble of crawling under there.
