should fit.......you didn't list the width and bs, I would assume if they are the correct bolt pattern that they would most likely be acceptable in the bs area. Should look real good!
Yes it will rub bad i had the same set up on my truck but i got 20's super lift makes a 2 inch upgrade you can get that will run you 600 dollars and it will not rub at all and it gives you a sick *** coil over suspention set up
I agree. The truck comes with a coilover suspension. Several members here and FTW are running 35's on 04-08 F-150 4x4's with 4 and 6 inch lifts with no problems.
