back spacing question
Originally Posted by ckyuv
ok so on my truck i put 35 inch tires on it and they are hitting my frame when i turn. people are telling me to check my backspacing but do i need more or less? how much backspacing is to much?
No, less backspacing pushes the wheels farther out. More backspacing pulls them in. You are right about possibly eliminating rubbing in one area only to create it somewhere else however.
If you tell us what kind of truck you have along with what tire and wheel we will be able to help you more.
i have the 2002 f150 2wd, 4.6L. i put a 3 inch body lift and a 2 inch leveling in the front. i have 35inch pro comp all terrains on my stock rims. i knew i shouldnt put them on stock rims but i did untill i could find out what kind of wheel i needed. the tires rub on the frame and another bar that i would guess would be like a sway bar?? it connects to each controll arm and connects them...
