Question before I order tires and leveling kit!
So after a long time of researching I am finally going to order tires and a leveling kit. I plan on getting 285/65/r20 (34.5 Diameter 11.5ish wide) BFG All Terrains with the 2" AS leveling kit. I have a 2007 F150 Supercrew with the 20" OEM wheels. I see a few people running these tires with a 2.5" leveling kit, but will they fit with a 2"?
Thanks,
Thanks,
Originally Posted by HuntinDawg
Thanks Smitty....Does your truck sit pretty level or does it have some front rake to it? The reason I want to go with the 2" instead of the 2.5" is because I do not want the front nose of my truck sticking up. I do not mind front rake.
Ricky Bobby, that is only a 2" kit on your truck? I looked in your gallery and the front end is noticably higher. I was thinking of adding a 2" instead of the 2.5" to mine just because I tow a trailer alot and dont wont the front end up in the air but if you just have a 2" maybe I should reconsider. Do you have anything in the bed of your truck in the photo?
I put on the 2.5 as on the front, and the blocks on the rear (added 1.5 total lift on the rear). The rear was a cinch to install, and I didn't like the look I see on the street often where trucks look like a boat before it planes. Why not consider the rear blocks? I got a 2" lift at the midpoint of the truck.
