Spare Tire
Brace the spare so it won't fall on you and cut the cable with a dremel.
Then you can remove the entire winch system from the truck and ****can it.
I swear whoever at Ford came up with this bright idea ought to be shot.
A lock on the spare and one 'key' that is easily lost.
I guess we should just be glad only 01-03 have this issue.
my 04 uses the ignition/door key to open the lock, but i agree, the idea of putting the spare in the place it is is not a great idea. If you drive the truck in places like i do, that is a **** poor mounting location, things always getting under the chassis and hanging up in the back end. I am thinking of plating the undercarriage with some polished diamond plate steel.
My complaint with the spare is
from 97-00 you just put crank handle directly in the hole...
from 04 and up you use a real key (ignition key)...
but, the years 01-03 they came up with the bright idea of putting an appendage (spare key socket) onto the crank handle.
The 'appendage' is a [one each] and may be in the glove box, under the seat, behind the seat or most likely, long gone.
It wasn't something you could put on your keychain.
And it didn't get the use necessary to keep it handy.
Need some people to come up with bright ideas as to a good fix
because this is about the 3rd or 4th thread I've read from these 01-03 people
and there will probably be hundreds more down the road.
