Kinda Confused (Wheel Bearing)
Old 12-10-2007 | 09:27 AM
Skrewd's Avatar
Ok, So I'm convinced that I have a bad wheel bearing, I just cant tell which one. I really FEEL like its on the Drivers side, but the noise goes away when I turn right, which would mean it was coming from the left passenger side, am I correct? I need to order this Bearing TODAY, so please help!
Old 12-11-2007 | 09:04 AM
Skrewd's Avatar
Old 12-12-2007 | 10:26 PM
John Patterson's Avatar
bearings
How many miles do you have on your vehicle? I usually repack bearings every 40K miles or so or when I replace brake pads. Why don't you remove them, clean and inspect, and if necessary, replace them with some good quality bearings available at most auto stores.
Old 12-13-2007 | 12:19 AM
Nettershakes's Avatar
Jack up the truck and check the bearings yourself. Should be pretty easy. My buddys wheels were making noise and as soon as we jacked it up i put a hand on the tire and it wobbled back and forth. Not a good thing.
Old 12-13-2007 | 01:34 AM
MmmBuckles's Avatar
just wait till its starts smoking. then you'll know for sure which one it is
Old 12-13-2007 | 01:43 AM
azmidget91's Avatar
jack it up like said before and rotate them the bad one should feel rough and also see if it wobbles
Quick Reply: Kinda Confused (Wheel Bearing)
