Need Info on Wheels
Need Info on Wheels
I'm looking for a second set of wheels for a 2002 F150. Originals were 235/70/R16, I got the 255/70/R16 option.
I found a set of 2000 F150 wheels (235/70/R16, with supposedly good tires) on line. I'm more interested in the wheels, than the rubber, but that would be a plus.
Can anyone tell me if the 2000 rims will fit on the 2002? Any input would be appreciated. Thanks...
They should but only thing you might ask the person you are getting them from is the manufacture date on the truck they came off of. Reason being in 2000 about mid year Ford changed the lug size from 12 to 14mm if memory serves. The bolt pattern is the same...I would think it would make a big difference but just in case might see if they are the smaller ones.
