Bigger Tires..ReGear...Programer..or nothing at all
Originally Posted by chip_in_nate
i just put a 6 inch lift with 35 inch procompt extreme MT tires on my 4x4...do i need to put a new gear ratio on the tranny, can i just get a programmer, or will it be ok the way it is...its a 5.4 V8
Most ppl that go with 35s and have the 5.4 litre do not change gears. That is the main reaason for chosing the 35s over the 37s. You probably already have 3.73s so that is not a bad gear for 35s. In thew future if you decide to go bigger and put a 3" lift on top of the 6" and go to 37s, then you will definately want ot regear, but I dont think it is necessary now.
I like my Edge Evolution, I have 35's and a 3.73 rear and at least it make's it shift a lot better but anytime you go to taller and heavier tires it is better to re-gear to keep your rpm's more in the power-band. Taller tires reduce your final rear end ratio and drop your crusing rpm's too low sometimes.
