Tire pressure?
Originally Posted by MercedesTech
load range E and max PSI is only 65 ? Strange. Aren't most E rated tires max PSI 80 ? I also have Load Range E tires. I usually run them around town at about 40 PSI. If i tow I up the PSI usually to about 60 - 65 and if I go off-roading I usually air down to about 25 psi or so.
Also, if your vehicle was OE LR E tires, and had TPMS, it would be set to light the low pressure light at about 46 psi.
Thanks for the advice. interesting to know about the newer LR "E" tires. I have not yet seen that, but its interesting. My tires are fine at 40 psi. I like em like that and these are by far not my first E tires. Also, there is NO way our rear end, on the scale is 2,000 lbs on each tire. Can't be. My whole truck weighs what ? Just under 7k ? I find it hard to beleive more then half of my trucks weight is sitting over my rear axle (carrying an empty load) ? That would mean the bed and rear-end is heavier then the engine, tranny, front clip, cab seats and my fat ****. There is no weight back there. Maybe going up a hill ? There just can't be 4,000 lbs over my rear tires.
Scroll down on this report. There is a chart with the PSI settings for the TPM system for each load range of tire.
http://www.nhtsa.dot.gov/cars/rules/...ule.html?name=
OOOOH, gotcha! Well I was talking doing an empty haul. No weight, just driving. and that is why i am VERY happy i do not have that TPMS. Like I said, these are FAR from my first set. E rated tires is just about the only thing I have run on my trucks. i usually stay right between the 40 and the 45 psi mark. And if I load up my bed, i fill up my tires. I will never pull or haul a load with 40-45 psi. I usually bump it up closer to 60-65.
The recommended pressure for the LR C tires that came on my 04 was 40, which if you calculate it out was for 2000lbs per tire or, 4k for the axle.
really interesting. Maybe I will try bumping it up a notch... but like I said, I usually fill it up to right between the 40 and 45 mark. Right around 42-43. You say you run yours at 50psi ? Sounds like the ride would be too rough ?
Originally Posted by svt2205
FWIW, Ford's put C range LT tires on the F150, not E's.
Also, a 8200lb GVW vehicle does have an option for LR D tires.
