can't remove rear brake rotor
have a 2000 f150 i was trying to replace the rear brake rotors today and couldn't get them off. i think that the e brake shoes have probably worn a groove into the drum locking them on there. i went to the back of assembly to try to re adjust the adjuster to the all the way in position, but couldn't even turn it either way. i soaked it in wd40 to try to loosen it up but didn't do much, any other suggestions. also any one know which way to turn the adjuster to make it go in, i was just guessing it was up but it didn't matter because i couldn't turn it anyway.
thanks for any help
kevin
thanks for any help
kevin
