what wheel
I am just jumping in on this thread to not start another...but I have already searched and did not really find my answer to this yet.
I understand that the wheel width on the 2004 17 inch wheel is 7.5 inches and the backspacing is 5.5 inches, but all the ads on eBay for wheels are using offset to describe the wheels, not backspacing.
I have calculated that the stock 2004 17 inch wheel is a +44mm offset, can someone confirm this? Also, if I find a 17 inch wheel with the 6/135 lugs for the f150 or the lincoln or the expedition in the 44mm offset I should be pretty much identical to the stock wheel specs correct? Unless, of course, the real offset turns out to be 30mm, but I don't think so.
44mm or 30mm offset...that is the question.
