Don't understand tire sizing???
Originally Posted by Super FX4
I want to put Pro Comp 18" by 9" series 7005 wheels on my FX4.
I wan't Nitto 33" tires but dont understand the sizing (like 305/40/18) ect....
What size do I order to fit my wheels and be 33" tall tires?
http://www.miata.net/garage/tirecalc.html
Diameter is shown.
With tire sizes, the first number is the width of the tire in millimeters.
The second number is the aspect ratio - percentage of the width that is the sidewall.
The third number is the rim diameter in inches.
My new tires are 295/70/17. That means they are 295mm wide (roughly 11.5"), 70% of the width is the height of the sidewall (a little over 8"), and that they are sized for a 17" rim.
Hope that helps a little.
Here's a pretty good website/calculator that might help you to visualize metric tire sizing.
http://www.bigcustomwheels.com/rt_specs.jsp
Taking your example (305/40-18):
The 305 (in millimeters) is the width of the tire at its widest point. This means the bulge, not tread width.
The 40 is the aspect ratio (a percentage), a way to denote the sidewall height. Basically 40% of 305mm = sidewall height (wheel to tread).
The 18 is the wheel diameter.
So...305mm is the width (12.0"), sidewalls are 0.4*305mm = 122mm (4.8"), and wheel diameter is 18".
4.8" + 18" + 4.8" = 27.6"
You've got a 27.6" x 12" R18 tire in standard sizing. Kind of an odd size , but the math works out the same for more common sizes.
Edit: I need to learn to type faster...three replies in the time it took to write mine...sheesh.
