Close to Buying Last Question
Old 02-19-2008 | 12:05 AM
BigRed91's Avatar
Exclamation Close to Buying Last Question
This is my last question before i buy but i just want to make sure. Is it possible to get 305-70-17 with a 2 inch leveling kit and this would be on the stock rims. I think these tires roughly come out to 33.9 inches. I would get the Nitto grapplers. I don't know if i have enough backspacing or if the tire will rub. I definitely do not want the tire rubbing. If someone could help me out i would greatly appreciate it. Thanks
2004 Fx4 scab
Old 02-19-2008 | 12:36 AM
hawg_man's Avatar
they'll fit great!
Old 02-19-2008 | 07:52 AM
BigRed91's Avatar
It says on the Nitto Website that they only make the 305-70-17 for a 17 rim that is 8 inches wide and mine is 7.5. Does it matter?
Old 02-19-2008 | 09:31 AM
david@bonesenterprises's Avatar
Former Sponsor
It will be fine. Just a little skinnier than the other but it will be fine.
Old 02-19-2008 | 10:08 AM
Russ47's Avatar
I had 305/70/17 buckshots on my 07 F150 4x4 on 17x8 Eagle Alloy 114 wheels and i had no rubbing at all, heres some pics
Old 02-19-2008 | 12:40 PM
BigRed91's Avatar
Yea but you put those tires on 8 inch wide wheels i am wondering if you could put tose on 7.5 inch wide wheels and not have them rub. Thanks though for your input
Old 02-19-2008 | 01:10 PM
Russ47's Avatar
the wider the wheel the more chances of rubbing
so if i had no rubbing with 8" wide wheels you definetely wont have any rubbing with 7.5" wide wheels...
Old 02-19-2008 | 01:13 PM
fx4 for life 79's Avatar
i have the 2.5 inch kit with 305/70/17 nittos
no problems what so ever
Old 02-19-2008 | 01:23 PM
A lot of people run 315's on stock wheels with no problems.
Old 02-19-2008 | 05:28 PM
Simple Man's Avatar
I'm running a 33x12.50 on my stock 17" rims with the 2.5" leveling kit.
Old 02-19-2008 | 08:21 PM
BigRed91's Avatar
Exclamation
yea but i was thinking about getting only a 2 inch leveling kit...all of you have a 2.5 leveling kit. Would the 33.9 fit? O and Russ how are the Buckshots?...are they quiet and ride smooth? Thanks
Old 02-19-2008 | 08:38 PM
wandell's Avatar
Yes, they will fit.
Old 02-19-2008 | 08:58 PM
BigRed91's Avatar
General question about Backspacing....If I get 305/70R17 on a 17x7.5 rims do i have the backspacing to fit these? Thanks
Old 02-19-2008 | 09:00 PM
wandell's Avatar
On the oem wheels? Yes.
Old 02-20-2008 | 12:03 AM
dre23's Avatar
Okay, sorry, it's late & I'm a little slow...So just to be clear, I have a 2007 4x4 SCrew w/a 2.5" leveling kit.
1.Will I have any problems if I install a 305/70/17 (32.8"x12"x17")?
2. Is it correct that my rim size must be 9inches or less?
3. Does my backspacing matter, and if it does is 5.5" of backspacing okay?
4. Is it better for the fitment for the backspacing to be higher or lower?
5. Will I have to do any front valance trimming w/this set up?
Thank you guys SOOOO much. Wheels & tires are so foreign to me and I am just trying to read, learn, and soak up as much info abou them as possible & I have learned so much on this board.
Thanks again Guys...you all rock!!
Quick Reply: Close to Buying Last Question
