Tire Term Question
Tire Term Question
I am going to get the Nitto Terra Grappler and I was looking at the size and specs. I am pretty sure that i am going to get the 295-70 R 17 and i was curious between the D range and the E range. I don't know what these do so i don't want to make a mistake. if you could tell me which one is made for what and which one is better i would appreciate it. Thanks for any advise you can give me.
Skyler
Skyler
you can use either it wont make a difference. check out this site it should answer all your questions. http://www.tirerack.com/tires/tiretech/tirespecskey.jsp
If your set on that size tire, it's easy, Nitto only makes a D in that size
I recently got the 285/75/16's and difference between the load of the D and E was about 350, I don't think I'll ever tell the difference so I got D (didn't know that until after I looked at them though).
If you want E, you can drop to a 285 or go up to a 305 if it fits...
The Nitto website is pretty good for sizes and specs.
I can't tell you a difference since I've only had D rated tires. I had P tires on this truck before I got the Nitto's. I assume my tires are a little lighter than the E's, but my truck did everything I ever needed it to with P tires, so I was ok with just D's.
I'm not even close to an expert, but I did a lot of research before I bought mine last month, maybe one of those guys can chyme in and give a better answer.
