08 fx4 s-crew 20x10????
Old 02-23-2008 | 08:31 PM
pcernuch's Avatar
i plan on 2.5 autospring leveling kit, 305/55/20 nitto terra grapplers, and i am stuck on the wheel size. what would 20x10 with 4.5 back space look like? how far would they stick out?? i am thinking i would like around 1-1.5 inch past the fender. i found a killer deal but if they wont look right i can see why its such a good deal on the rims. please help. thanks.
god bless.
Old 02-24-2008 | 01:24 AM
Russ47's Avatar
if i did the math right they'll stick out around 3-3.5" more then stock set-up
Old 02-24-2008 | 09:53 AM
hivoltagefx4's Avatar
Your truck would pretty much look like this:
Old 02-24-2008 | 03:50 PM
wandell's Avatar
They will stick out 3.5 inches farther than the oem 17 and 18 inch wheels.
Old 02-24-2008 | 05:40 PM
pcernuch's Avatar
sorry if its a dumb question, but is there a "formula" i can use to figire this out? 4.5 back space will stick out 3.5 inches further than stock "too much in my opinion" so what would i be looking for to stick out 1.5-2 inches on a 20x9inch i can choose 5.7 or 6.18 backspace. thank you sir.
god bless.
Old 02-24-2008 | 08:46 PM
wandell's Avatar
The oem 17 and 18 inch wheels are 7.5 inches wide with 5.5 inches of backspacing. So, that 10 inch wide wheel is 2.5 inches wider and has 1 inch less backspacing. 2.5+1=3.5. A 9 with 5.7 inches of bs would stick out about 1.5 inches farther than the oem wheels and a 9 with 6.18 inches bs would stick out about an inch more.
Old 02-25-2008 | 10:17 PM
pcernuch's Avatar
wandell thanks a million. the specs you gave with 5.71 sticking out 1.5 and the 6.18 about 1 inch is that a measurment of installing just a rim to check fitment past the fender, or is the 1.5 and 1 inch measurement including the tire balooning over the rim??? sorry i search and searched and your name came up in every thread. i appreciate the time and effort you have given to my cause here. plus the wife will kill me if i drop $2500 on rims and tires and i dont like how they fit. thanks again.
god bless.
Old 02-26-2008 | 02:42 PM
wandell's Avatar
No, those figures are just how much more the wheel itself will stick out compared to the oem 17 and 18 inch wheels.
