SOURCE: Pics for Trucks using Leveling Kits!
OK guys, in my current new guy state of searching over and over for what everyone else seems to be searching for, I am hoping this thread will act as a 'repository' of sorts for pictures and info.
The intent:
- Year of Truck, Type of Truck (Including Trim Package), 2WD or 4WD
- If you have a Leveling kit installed, please note how high (2", 2.5", etc).
- If you have an Add A Leaf (AAL), please post the details on that.
- If you are using an aftermarket tire / wheel setup, please post the important info - make / model (if you will) along with size and backspacing where appropriate.
Question: Is there a difference in perceived 'stance' when adding the same size leveling kit / AAL to a 2WD vs a 4WD ? (I will edit the header once I get an answer so it is here at the top for the search function).
WHILE WE WAIT...(lol) I finally found a truck that did not get sold from under me to replace my 01 S Crew and need info. This one will be a 2WD 2004 Lariat S Crew and I have plans, including a kit and tires (Obviously) in mind. Thanks!
The intent:
