Biggest tires on OEM 20's?
I'm running 305/55/20's which are 12" wide. I have the oem 20's and they do rub slightly. The height is not a problem at all (33.2") its a combo of the offset of the rim and the width of the tire that causes the rub. I'm not sure about the tallest tire you can run but if you do not want any rubbing with oem 20's you will have to stay under 12" wide.
Originally Posted by ATOM
BFG makes a 285/65/20 about 35 inches high and almost 12 inches wide the tallest and widest tire you can fit with NO rubbing. several guys are running them on here.
That Nitto tire would be a great fit. I have the same size, only in a GY AT/S and it works great in every aspect. ZERO rubbing, good width on the 8.5" wheel, and performs well for what I do. That said, my next tire will be a bit more aggressive. I like the look of sidewalls that have lugs on them.
Originally Posted by knighj1
325/60/20 bfg a/t is what I have, but if I could go back I would have saved myself somemoney and gone with the 285/65/20, b/c you can save around 100 a tire and they are not much smaller,but do I regret the decision I made????
NOT FOR ONE MINUTE
NOT FOR ONE MINUTE
