problem with my new xtreme a/t tires!!!
so i got me some 325/60r18 pro comp xtreme all terrains to put on my ultra goliaths the other day i have a 2.5" leveling kit as well. i took it to the tire shop to get them mounted and i got a call back a while later saying that they hit the control arms and i have to get wheel spacers to allow them to clear. i was wondering if spacers was my only option or is there another way to get rid of this without getting rid of my tires?
Originally Posted by brodystephens
they are 18x9 and have +25 offset im not too sure how you calculate backspacing from that
You won't be able to fit those tires with those wheels without spacers.. You will need a wheel with specs very similar to that of the stock wheels. The stock specs are 18x7.5" with about 5.5" of BS.
With the 326/65R18 you will have rubbing as is and I would say if you want to keep your wheels then go with the spacers.
they said that right when my truck sat on the floor the tire would hit just barely on the control arm and they are 325/60 not 325/65
Originally Posted by chumFX4
325/60/18 on 18x9 wheels with 5" backspacing, 2.5" Daystar Leveling Kit:
