325/60-18
Does anyone make a tire in a 20" wheel that is equivalent to that size? I love the width of that tire. I also go back and forth between 33's and 35's with a leveling kit. It seems like some tires look stuffed with 35's and some look great. It also seems like some 33's just don't look that much different than stock. Any help is much appreciated.
bf goodrich makes at ko's in 305/55/r20's (33.4") and 325/60/r20's (35.5). the second I think would be too big causing some rubbing issues. the first should fit and look ok. it is unfortunate they do not make anything inbetween. I just bought me some 305/65/r18 (33.7") tires. haven't mounted them on the truck yet but they seem so much bigger than my 285/70/17's (32.8") tires. I am glad I did not go bigger as these tires seem vary big and heavy. once I get them mounted each rim and tire together will weigh arround 100 lbs I can just imagine how fun it is going to be rotating the tires. if I had gone with the 325's they would probably be 120 lbs. plus the 305's wont suck so much gas out of the gas tank as the 325's.
