Will this work?
Will this work?
Ok I ordered my 2.5 inch leveling kit from autospring, and I am ordereing either the moto metal 951 chrome rims or the XD rockstar rims...my question is what is the biggest tire i can run...they will be 20 inches....is 285/55/20 to big or can i fit more....thanks for any help....o ya i have a 2wd.
Edit/Delete Message
Edit/Delete Message
That would probably be your best bet as far as tire size. As for fitting them, that will depend on the wheel. If you use an 8 to 9 inch wide wheel with 5 to 6 inches of backspacing you should be fine. If you go to the far extreme on those wheel specs (9 inch wheel with 5 inches of bs), you will probably have to do some trimming.
