need some help
need some help
hey guys i need some help. i have a 2002 xlt 4x4 with 285/75/16 on the stock rims now and i am getting a 3" body lift. so how big of a tire can i put on when i get the lift put on? also is there any way i can get wider tires with the stock rims or do i have to buy after market rims? thanks for the help.
how wide are you talking? you can run up to a 12.50 width on stock wheels with little or no ill effects...im running a true 33x12.50x17 on my stock chrome clad lariat wheels which if memory serves are 7.5 inches wide... just have to watch your air pressure and be sure to not over inflate as it will cause the tires to swell in the middle and wear out quickly
I'd recommend the Westins. They mount to the body and work great with a body lift. Look for them at www.autoanything.com or just about anywhere that sells automotive accessories.
