Replacing pads and rotors
When you check the pad, if it looks like there is a good amount of pad material you're good to go... if you are questioning it, you can always take a pic and show us.
I know these are pads, not the shoes... but you can get an idea of what a worn pad/shoe looks like and a new one
JNC,
Sorry about the link and as I have been away, I was unable to correct the link...Brakes are easy to do but there are a few tricky items to consider...The bolts holding the caliper bracket tot he spindle can be a real pain to remove, I am lucky as I have an impact but if you don't it can be hard to extract them.
Try this site for a whole bunch of F-150 repair items..I copied the site as it came up in "my favorites" so it is a little different.
http://www.fordf150.net/howto/
My F-150 Heritage has rear discs and there is a very distinct difference in the two, if you had rear discs-you'd know right away just looking at them.
What the difference in the slotted and the drilled? And I see that the stoptechs have one with both.
also the drilled and slotted both allow the gasses produced during breaking somewhere to go, if you have ever been going somewhat fast and had to slam on the breaks you might have noticed the breaks feel like they are pushing back, that is because of the gasses
I just wanted to throw this in. There are many F150s out there with rear-discs. I'm not saying that the truck in question in this thread has rear-discs, but many do. My 2000 F150 has 4-wheel discs. The only brake-shoes on the truck are inside the rear-brake rotors and they are for the parking brake.
