F150 Abs Problem
F150 Abs Problem
My 1998 F150 4x4 With Rabs Has The Terrible Abs Light On. In Recent Comments A Control Module On The Left Frame Rail Was Mentioned. I Can't Seem To Locate This Module For Testing. Also Does The Speed Sensor In The Differential Have A Resistance Check? If So, What Should It Read?
When the unit goes bad it can cause rear lockup problems that can be eliminated by removing the electrical connector. Check to be sure someone hasn't already done that.
If you end up needing the module check out my site www.TascaParts.com we should be able to save you some money.
