I recently brought a 04 supercrew fx4. It is totally stock, but my question is if i put a 2.5 leveling kit on it, what is the biggest tire I can put on with no rubbing? As far has height and width. Thanks
You can fit a 35x12.50 using the oem wheels but they will rub slightly on the control arms at full steering lock. Anything smaller shouldn't rub at all.
The diameter of the wheel doesn't matter. It's the width and backspacing on the wheel. A lot of people use 33x12.50-18's but the 325/60-18 (33x13.00) seems to be a more common size. I'd suggest a 9 inch wide wheel with 5 to 6 inches of backspacing.
