Need lowering guru wheel help
Here's the deal, I've got my eye set on some wheels... But after doing a lot of research I believe they're not going to fit... Good thing I haven't bought them yet.... Anyways, I'm going to lower the truck and I'm not quite sure the offset I need to tuck them... I'm probably going to go w/ the Belltech 3/4 w/ nitros. And here is the wheels I want....
Bad part is that they're +15mm and I've heard that the biggest offset you can run on 22x9.5's is +35mm to clear... These are +15 or +10... *can't remember off the top of my head... I hope somebody has pulled off tucking some low offset's like 15 or 10 because I don't want to start searching for wheels all over again, but I will if I have to.
Here's the deal, Bad part is that they're +15mm and I've heard that the biggest offset you can run on 22x9.5's is +35mm to clear... These are +15 or +10... *can't remember off the top of my head... I hope somebody has pulled off tucking some low offset's like 15 or 10 because I don't want to start searching for wheels all over again, but I will if I have to.
I would recomend 2/4 over 3/4. Trust me its very hard to align the truck on a 3" coil drop
