stock wheels with 2wd procomp 6"????
Call Pro Comp and ask them if you're doing the lift yourself. If not, ask the shop that is\may be installing your lift for you. I was all ready to pull the trigger on the Fabtech years ago but once I found out my OEM wheels would not work, due to back spacing issues, I had to research another lift that would work (RCD).
