Brakes or somthing makeing noise
I have a 2004 F-150 crew cab. I had my brake and rotors replaced 3 weeks age. Yesterday I noticed my front left wheel is making a clicking moise when I trun left or right. I lifted the wheel off the ground and checked the bearing for looseness, everything seems to be tight. Anyone have any idea what may be going on.
Thnks
MJ
Thnks
MJ
There is a lot of info on this problem you might want to do a quick search.
Is it a clicking or grinding noise? If its a clicking/ticking/squealing noise it could be worn pads, loose pads, lack of disc brake quite on pads backing, rust in between rotor and caliper, dry sliders, backing plates hitting rotor, or any other metal on metal contact.
If its a grinding noise you might have an IWE problem.
