Longer than stock brake line?
Old 07-28-2008 | 04:21 PM
madmaxwell87's Avatar
I recently put a 3" block on my 2wd 00 150. The main rear line (frame to axle) is now too short. I searched here and online and everyone only makes lines from the valve on the axle out to each drum. But I don’t need those. Does anyone know how to make the line longer or where to get a longer line?
Old 07-29-2008 | 02:35 PM
bump-
classic tube said they could make me a longer line but im not looking to spend hundreds of dollars. anyone know if just the same line but for a stock 4x4 model would work?
Old 07-29-2008 | 05:58 PM
keith97xlt's Avatar
so the flex line is to short?? might try a line from a 250 or 350 as they already sit fairly high stock. its worth a try although they might be a wider flare where it connects to the frame hardline im not sure.
Old 07-29-2008 | 06:02 PM
i think im going to have to go to a ford dealership and ask to see a 4x4 150, and maybe even a 250/350 line and see if their longer and/or will work. what yes its a flew line, i need is the line that goes from the frame to the axle on the drivers side
