Brake almost to floor
provide more details... did the problem repeat or was it a one-time thing? Did you have brakes or not? Do you mean that vacuum at the booster was good? It wouldn't be a vacuum issue... that would make the brake pedal hard, not soft.
from your very brief description, it sounds like maybe you blew a brake line. It it broke on that apply the brake fluid reservoir would still be full. It would take several applies to pump out enough fluid to see a difference.
Pump the brake pedal 5-10 times and then get out and look for where the brake fluid is coming from. If its a broken line you'll see the fluid.
