I thought i blew a brake line. All i found was the " breather" line coming off the tee fitting for the rear brakes, blew off. Fixed that and now when i pump pedal, fluid comes out of that breather line.
There are no "breathers" on the brake lines. The brake line should be a sealed system. Sounds like that "breather" should be hooked up to one of your rear calipers.
