e-brake adjuster
e-brake adjuster
I'm replacing the whole works in the rear before winter since the trucks shakes something horrible with any pedal.
I'm not sure I understand how the self-adjustment thing works. I just can't see in my head, how the parts I'm looking at there on my truck, self adjust. Maybe someone can explain it, maybe not.
The real question I have is what direction do the adjuster gears go? Towards the front, rear, both or either? If both, which one is which? I didn't pay attention when I was rushing through the dissassembly stage last night.
Well, if it's like mine, there is a little plug on the backing plate. Remove it, and you can access the adjuster. But, if yours was shaking (like mine) you need to pull the rotors and inspect. I found mine blew the axle seal contaminating the parking brake and pads with gear lube. The brakes were grabbing and very uneven. I am finishing mine up tonight..
New Rotors
New PB Shoes
New Pads
New Bearings
New Seals
Fresh Gear Lube
Painted Diff Cover
Polished Wheels
A the fun continues...
New Rotors
New PB Shoes
New Pads
New Bearings
New Seals
Fresh Gear Lube
Painted Diff Cover
Polished Wheels
