tire pressure in new 315/75/16 tires
I just went from 285/75/16 BFG mud terrains to 315/75/16 Pro comp xterrians. They are load range D & the only pressure reading I could find on the tire sidewall was (50 psi cold). Im assuming this is a max pressure reading. Normally there is "max" on the sidewall for pressure ratings.....
I ran 40psi at all 4 corners on my BFG's & inflated the rears to 50psi when I was towing my travel trailer, all with great wear results. The shop that mounted & balanced the tires recommend that i run these Pro comps at 50psi all the time on the street. Does this sound correct? im looking for daily use street pressures & also towing pressures. I appreciate the input!
