Warped Rotors Warranty Item
My 06 has just under 18k miles. 100% drivetrain stock. My front rotors are warped.
Is this a warranty item? I have to get the booster vacuum line fixed and the overhead bin is broken - true factory defect. Should I get the brakes covered as well under warranty?
I know brakes are wear items and I did warp them with towing. I was within my towing limits and had a brake controler and trailer with brakes, but I still warped the rotors.
Will they cover them? I dont see it as abuse. Its an easy enough job, its just expensive.
If they do cover it will the rotors be turned or replaced?
my dad and brother both have reg cab long beds, 99 and 98 respectively and they have warped rotors on the front, my dad replaced his and a month later they were warped again. and he did not haul anything in the month it took to warp them. i have a 04 screw and my fronts are warped. ive just learned to deal with it becuase i believe it must be a ford thing. i may one day try some performance rotors with grooves or holes, but for now ive given up and accepted it.
just my thoughts.
just my thoughts.
Nope.. Not a warranty item at this point. I worked at a Hyundai dealer and rotors were only a warranty item for 12 months / 12K miles. After that customer pay and they were warped all time I think worse than these trucks. Maybe someone working at a ford dealer will chime in but I doubt you'll have any warranty. I would buy some upgraded rotors especially if you will towing. I dont recommend cutting these rotors especially if they are warped.
Warped
I have an 06-4x4 scab, bought it used with 24k, had it a month or so and noticed the wheel shimmy a little at highway speeds when I hopped on the brakes, took it back to the dealership, they tried to turn all four discs, but then decided to replace them all. It sounds like the torque on the wheels is very important. Go talk to the dealership, raise a little cane, they shouldn't be trashed with 18k miles. Good Luck
