Verifying no rub.
Old 09-24-2008 | 06:20 PM
OC Dan's Avatar
Verifying no rub.
OK, first post and I have read many threads on tire fitment and have learned a ton.
In any case, just got an 08' FX4 Screw and want to verify before I drop the dough that the following will fit without any rubbing:
Pro Comp 18x9, 5936 Knight Chrome 6x135, 0 offset, with 5" B.S. wrapped with Nitto Terra Grappler 325/60/18
I will be adding a Pro Comp 2.5" leveling kit.
From what I have read it will work without rub, but want an "expert opinion"
Thank you.
Old 09-24-2008 | 10:21 PM
mattd17's Avatar
i was running the same tires with 9005 series wheels, 18x9, 5" BS, 0 offset, and the 2.5 AS kit..... yes, mine did rub at full lock. i had to trim a minor piece of the valance (about 1/2" x 2.5") from each side. And, i also had to build a bracket to pull the front mud flaps towards the rear just a little.
those tires are pretty wide..... if you chose a basic 33"x12.5" i think you would have better luck.
BUT...... im no expert in any means, just my .02.
Old 09-24-2008 | 11:46 PM
wandell's Avatar
Yep, they will fit, but you may have to do some minor trimming.
Old 09-25-2008 | 03:09 PM
OC Dan's Avatar
Would a 285/65/18 Terra Grappler be a better choice to ensure no rubbing? I really don't want to trim anything on the truck if possible.
Old 09-25-2008 | 11:45 PM
wandell's Avatar
Yes, they are approximately the same height (33 inches), but they will be 40mm narrower.
