If I put 35's on can I lift the front a little with cranking the torsion bars? What in height would I gain or should I leave it alone? Thanks for the info on 33's or 35's. The trucks look good.
you have a 2006 you dont have torsion Bars. If you want to clear 35's you will need to add a 2.5" spacer leveling kit. Or the Bilistien adjustable coilovers i think they are 5100's (that would be what i would do)
And the easiest way to do this is to keep the stock wheels.
NOTE Some get away with using aftermarket wheels and 35's on 2.5" leveling kit but there are WAY to many variables.
