Replacing a RABS Valve / Brake Bleeding
Blue is confusing the valve for the sensor.
Take a look at the flares on the tubes to make sure they look ok. I wouldn't expect any issues.
To bleed, just do a standard pedal bleed. You can find details on here if you search around the forum. Basically go to each wheel, open the bleeder, and then pump the pedal (close the bleeder before releasing the pedal) till the new fluid reaches the wheel.
